th400 rear gears?
Old Nov 2, 2004 | 02:39 PM
liv2race's Avatar
Default th400 rear gears?
i have a th400 with 3.23 but i want better ets so can i go with 4.10's or is it too much gear do i need 3.73's? i am not sure i dont want to buy 2 sets of gears
it is just a drag queen so fuel economy is not a big deal
the car weight is 3600 with me in it stall is 3800
th400 gear ratio is standard
thanks guys
Old Nov 2, 2004 | 04:14 PM
john kilgore's Avatar
Default trans gears
thanks guys
lf you install a 2.75 gear set in your 400 your car will think you have a 3.59 rear end, and a 3.00 gear set will be a 3.91 good luck
Old Nov 2, 2004 | 07:43 PM
liv2race's Avatar
thanks
but i was wondering on rear end gears does anyone have experience with a th400 and rear gears? what rpm's in the quarter will you push with 4.10 or 3.73?
thanks
Old Nov 2, 2004 | 11:00 PM
Navy David SS's Avatar
4.30's here. Th400 - 4200 stall now - 200 shot out of the hole. Standard TH-400 gears. Shift at 6500-6600. Use 30x9 Goodyear slicks. Cross the traps at about 6500. Best todate - 1.40 60'; 10.49; best mph 129.9.
4.10's on 28" will work
David
Old Nov 3, 2004 | 01:28 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have 3.50's, 28" slicks, and T400.
I had 4.10's before and I was buzzing a lot of rpms all the time.
I plan to cruise a lot in 2005 so I wanted some gas mileage.
Old Nov 3, 2004 | 11:08 PM
liv2race's Avatar
thanks guys that is alot of help
hey dave can you get a 30x9 under a stock f-body or did you tube it?
also john what were your r's at the end of the quarter with 4.10's
thanks all posts have been really helpful
By Brett Foote | 2026-06-04 05:00:17
