converter, 3.42 gears or both?
Old Dec 11, 2004 | 10:41 AM
onebad427's Avatar
The more I read the more I think I should have my converter restalled before I install it. I was thinking 2200 would be fine with the 3.42 Mosier,. This is not a drag car, although I will have to see what it will do in that capacity just out of curiosity. This will be a daily street driven hunter.
When finished it will be:
Aluminum MTI sleeved 427cuin. w/8.8:1(Speed Inc. says approx. 7400 redline),
ATI Supercharged D-1SC intercooled 15psi,
AFR 225 heads,
FAST 90mm intake and TB,
Forged bottom,
KOOKS LT dual cats(Damned Calif.!) Y into 4" into Spintec muff into dual 3" tails,
PATC Bionic 80 4L80E conversion w/of-course 2200 stall,
Mosier 3.42,
Custom Dyno tuning and reprogramming.
Could use some advice on the stall...
Old Dec 11, 2004 | 11:09 AM
Mooobunnny's Avatar
AFR 225 heads,
Forged bottom,
Mosier 3.42,
Even though that is a massive motor making TONS of power I would still go with a bigger stall. But I am sure your stall stalls much higher than 2200 with all of that power.
Old Dec 11, 2004 | 11:10 AM
Mooobunnny's Avatar
Originally Posted by GregWS6&z28
so keeping the 2.73's and getting a 3500/2.5 should be a good setup to go with?
That is what I would do...so far converter has been the biggest gain on my car....including my h/c package....lol
Chris
Old Dec 11, 2004 | 11:28 AM
GM Muscle's Avatar
Yep, that's the set up I run too. I can't complain much because it's been a pretty affective set up. However, if the car was a N/A only car I would probrably like to restall the converter to 3800 or so.
Old Dec 11, 2004 | 01:33 PM
96redformula's Avatar
Heck Do them all at the same time with the computer, That what I did.
