quick shifter question
Old Nov 17, 2004 | 04:02 PM
68birdls1's Avatar
Default neutral safety switch
does the stock shifter out of a trans am have a sensor or anything for it? does anything plug into it at all or am i just being crazy? thanks
daniel
Old Nov 17, 2004 | 10:38 PM
Nova5's Avatar
what?? are you having trouble or somthing? a little more info... i canna tell what ye want captin!
Old Nov 18, 2004 | 07:40 AM
68birdls1's Avatar
i have a 99 trans am shifter mounted in my car. no console or anything, just the shifter. on connected to the shifter is a lil arm, and that arm goes to a black oval shaped thing. and it has an inlet in it that looks like something is supposed to go in there. i will try and get a pic in a couple of hours, i just dont know what the heck it is lol
Old Nov 18, 2004 | 12:04 PM
68birdls1's Avatar
oh yea while i am at it, where does the nuetral saftey switch hook up to on this shifter? thanks again
Old Nov 18, 2004 | 02:33 PM
12secSS's Avatar
Neutral safety switch mounts on the passenger side, a tab stick in to it and slides around through the gears points. The shifter should have a solenoid (black oval shaped thing) that is electrically activated to lock out all the gears, until the brake pedal is applied. Then you can go from Park to any gear selection. Is that the thing you are talking about?
Old Nov 18, 2004 | 03:53 PM
68birdls1's Avatar
yes sir that is what i was refering to. thank alot, answered both of my questions with one stab lol
