Q for the pro's
Old Nov 22, 2004 | 11:08 AM
gonzo 6.2's Avatar
Default Q for the pro's
What would be the effects of a Rebuilt 4L60E with the band clearence set up on the tight side verses being set up on the loose side of the OE specs?How would the 1-2 shift characteristics vary?
Old Nov 22, 2004 | 11:22 PM
gonzo 6.2's Avatar
I think if a trans builder responds he would say a loose band would slap in harder and a tight side clearence would be cleaner and crisper and not so punchy.lets here from the guys that build the high HP 4l60Es daily.
Old Nov 23, 2004 | 01:34 AM
Automatics's Avatar
Restricted User
The clearence has very little to do with the application of the band, but more to do with the release of the band & the 3-4 clutch apply on the 2-3 shift.
Old Nov 23, 2004 | 01:36 AM
gonzo 6.2's Avatar
Would there be a difference in feel,tight verses loose clearence?
Old Nov 24, 2004 | 09:22 AM
gonzo 6.2's Avatar
Anyone have a specific answer about shift feel,up shift or down shift?
Old Nov 26, 2004 | 05:56 PM
Rock-On's Avatar
Default hey listen up
Okay here we go....simple answer....the closer to the drum the band is the faster the shift....to much clearance and you get long dragged out shift. So if your on the tight side you get a fast "chrisp shift". Loose side you will get a long "soft" shift. To tight you'll have band drag...becarefull...have fun! Hope this helps............ Dave
