Transgo? Fluid?
Old Dec 8, 2004 | 07:14 PM
PotentialZ28's Avatar
Default Transgo? Fluid?
Is a transgo shift kit the best for a 2002 A4 camaro? also, whats a good fluid to use with that sertup
Old Dec 8, 2004 | 07:44 PM
ULTIMATEORANGESS's Avatar
i have a trans go.it works great.
go with a dexron ATF or something similar.
Old Dec 9, 2004 | 11:34 AM
Ragtop 99's Avatar
If you want a shift kit, its a good choice. Just make sure it is installed properly.
Just use the factory recommended fluid and change it more often than the book says.
