transmission life with a big cam
Old Dec 12, 2004 | 03:29 PM
rufretic's Avatar
Default transmission life with a big cam
I'm putting in a f14 in the spring. I have all the mods in my sig and was just wondering how long my stock transmission will last. I've read that a large cam puts alot of stress on the tranny. I have a large cooler but I don't know if that will be enough. The specs on this cam are 232/234 .598/.598 on a 112lsa. How long do you think the stock tranny will last? It has about 25K miles on it now.
Thanks,
Lou
Old Dec 13, 2004 | 10:21 AM
01WS6/tamu's Avatar
It's life is directly proportional to the weight of the right foot on loud pedal.
Old Dec 14, 2004 | 04:28 PM
LS1SS4ever's Avatar
Me want to know also ...
Old Dec 14, 2004 | 04:33 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
It should live foreever below 500 hp.
Old Dec 14, 2004 | 04:48 PM
rufretic's Avatar
Maybe if I never race it, but whats the point of that. I know that nobody knows exactly when it will go, but I would like to get an average idea. Like people that had their trannys die after big cams. How much did you race? and How long did it last?
Example: went to the track once a month and raced on the street a couple time a week. stock tranny started slipping after 6 months
Get it?
Old Dec 14, 2004 | 06:04 PM
98Z28MrO's Avatar
Well... my buddy put a G5x3 in his car on a stock tranny and after three weeks and 1 track run... it started slipping pretty bad... woudnt have been too long before it died.
jxaxsxoxn's Avatar
The cam has no effect on the longevity of the transmission.
It's the increased power output the cam provides that might be tough on the trans.
And thats only power. It doesn't matter if you put in a cam and other stuff to get 500hp or just drop in a new engine that puts out 500hp. Cam has no direct effect on trans life.
Old Dec 14, 2004 | 06:11 PM
WILWAXU's Avatar
Well.. that might be true if we weren't talking about a computer controled tranny
Vacuum changes in the engine for so reason or another make these car do strange things with the tranny tuning.. usually affecting line pressure.
My advise. Have the car tuned by a reputable LS1 shop after the cam install.
Old Dec 14, 2004 | 06:35 PM
2MuchRiceMakesMeSick's Avatar
When you say affecting you mean lowering your line pressure? Or raising?
Old Dec 14, 2004 | 08:17 PM
jxaxsxoxn's Avatar
Yea... thats assuming one were to do the job right and tune the car with the new cam. My reply was assuming all was done properly. I sure wouldn't drive a car after a cam swap if it had mushy shifts....but you never know what people will do I guess.
Old Dec 14, 2004 | 08:28 PM
rufretic's Avatar
Ok, now were getting somewhere. So once tuned properly the cam has no effect on the transmission. It's the higher hp that starts to wear down the trans. So how about I change the question to: What is your transmission experience with cars making around 400rwhp? Can the stock tranny handle it? How long has yours lasted?
Old Dec 14, 2004 | 09:46 PM
WILWAXU's Avatar
If you plan to drive the car aggressively, you need to plan to have the transmission serviced regularly. Automatic transmission have a number of wear parts that will eventually need to be service, just part of the game.
Lower weight and less abuse on the tranny will yeild longer life span.. but all will need at least clutches after enough abuse.
Old Dec 14, 2004 | 09:50 PM
WILWAXU's Avatar
I wish we really knew. I've seen some screwy stuff..
IMO, if you plan to a rebuild the tranny, get a vacuum modulator. That helps eliminate one part of the computers areas of influence.
Old Dec 16, 2004 | 12:32 PM
When my tranny blows im going with a TH400 with gear vendors or possibly a 80e. I havent decided yet.
