tranny problems
Old Jan 28, 2005 | 12:13 PM
1998TA__1991RS's Avatar
Default tranny problems
my converter has been acting up lately (vig 2800) it will lockup and unlock really quickly when the tranny is cold but once it warms up it doesnt do it. i put a new lockup solenoid in it but it didnt help much, my tuner said it wasnt in the tuning, what else can it be??? i called precision and they said it would either be one of the two.
Old Jan 28, 2005 | 01:06 PM
Rock-On's Avatar
Default hey
Check the rubber o-ring on the end of the input shaft...a leaking seal will cause the situation your talking about.... Hope this helps...Dave
Old Jan 28, 2005 | 02:38 PM
so i have to pull the tranny out or just the pan off?
Old Jan 31, 2005 | 10:27 AM
Rock-On's Avatar
Default hey
Pull the tranny, it's on the input shaft.......do you have a transgo installed? Is this a built transmission?? which solenoid was replaced?? ....Theres two ..PWM, and lockup.....Hope this helps...Dave
Old Jan 31, 2005 | 01:00 PM
its fully built, trans-go kit, corvette servos, everything was redone,
Old Jan 31, 2005 | 05:14 PM
Rock-On's Avatar
Default hey
you mentioned a new lock up solenoid...there are two associated with lock up.......which one was replaced???? relly need this info.....to help you out....hope this helps Dave
