Need Some Advice
Old Feb 3, 2005 | 05:55 PM
gibsonlp1310's Avatar
Default Need Some Advice
I get some weird vibrations between 2000 and 2400rpm. Im thinking its my tranny mounts. Also sometimes when i shift into od it revs up about 200 rpms higher. Im taking it in next week to check since i got a 3yr warranty Should i have them check out the internals if they will. It has about 45k and i dont know if there is a shift kit or programmer. It shifts pretty hard though which is good.(its a 4L60E by the way)
Thanks.
Old Feb 3, 2005 | 06:03 PM
studlybilly's Avatar
Try jiggling the driveshaft on either side to test for slop or a failed/failing U-joint.
