What I learned swapping to a TH350
Old Jul 12, 2005 | 07:05 PM
LS13RDGEN's Avatar
I know that this thread is a little old, but I was curious about the bolt pattern on the TH350. Does it bolt right up to the LS1, or most of the holes line up? I am guessing (since I have not seen a TH350 up close) that it does not have the bolt hole at 12 o'clock.
Old Jul 12, 2005 | 11:29 PM
SUX2BU's Avatar
only five match up. two on each side and one in the upper left.
Old Jul 13, 2005 | 06:08 AM
LS13RDGEN's Avatar
That's good enough for me.
This thread is very informative, thanks guys for putting this info up there.
TH350 here I come!!!!
Old Jul 13, 2005 | 11:21 AM
josh99ta's Avatar
Sold The Fun Stuff :(
Haha, I guess after that "professional shop" left out my two top bolts and the car ran fine like that for two years we decided we dont need no stinkin eight bolts. We'll get by just fine on six, lol.
Old Jul 13, 2005 | 05:48 PM
Dragaholic's Avatar
9 Second Club NA
I'm concerned about the speedo myself. From what I've been told, I would need a T-56 reluctor wheel and speed sensor to make my speedo on a TH350. Reason being is that the T-56 and 4L60E reluctor wheels are different due to the amount of teeth. Now again, I was told that the 4L60E's reluctor wheel will slide/press right onto the TH350's output shaft, but a T-56 will not and will need to be machined and that you cant use a 4L60E reluctor wheel because it will throw off the readings. Anyhow, I would like the speedo to work and need to know what parts I need to buy to take them to my tranny builder tomorrow morning to install. Thanks.
Old Jul 13, 2005 | 06:27 PM
scalemaster's Avatar
if u have and A4 and then go with a TH350 do u have to reprogram ur comp.
or not
Old Jul 14, 2005 | 01:09 AM
SmokingWS6's Avatar
When switching to a M6 program. In hp tuners the m6 gear caculator will not work if you have an a4 VSS on your th350/400
Open up an a4 file to caculate your tires and gears ect.
copy and paste these values from the gear caculator to your m6 file
VSS Pulses/mile
VSS Pulses/rev
VSS Output pulses/mile
Trans Revs/mile
Old Aug 22, 2005 | 11:09 PM
flipiiiboi's Avatar
Default Thanks For The Info
HI ALL!! i just joined, and this site rocks! i was looking everywhere for help on what i should do w/ my elk i got rotting in the backyard! After seeing all this i think the LS1 is the way to go... I have a couple questions
1. The LS1 is rated at 310hp right? how much loss can i expect goin through the 350?
2. Should a plain rebuild of the old th350 be alright or should i go with Alto Red Eagle's Kit?
Old Aug 26, 2005 | 01:46 AM
Shinsetsu's Avatar
Originally Posted by Cokeroker
2001 Camaro Z28 formerly 4L60E. Now TH350
3. If you wish to use stock torque arm (or at least one that is still mounted to the tailshaft), then you should buy B&M's 700R4 to TH350 mounting hardware. It will work for the torque arm provision.
James Coker
Is this it?
http://www.jegs.com/cgi-bin/ncommerc...34&prmenbr=361
Old Aug 26, 2005 | 03:36 AM
Strahley's Avatar
Originally Posted by Shinsetsu
That's what I used, fits perfectly
Old Aug 31, 2005 | 02:08 AM
hookin-Z's Avatar
to the top
Old Aug 31, 2005 | 01:55 PM
  #32
kevredz's Avatar
1) I lost around 70rwhp on the dyno (MTI SAE #'s), but didn't lose any ET at the track.
2) I built the first one with the plain clutches, steels, and auto-valvebody. I trashed it bad! I then went back with the Alto Red Eagle clutches and Koleen steels, and I bought an Art Carr manual valvebody. I have ran about 30 passes on it and some in 100 degree track temps and it hasn't seen over 160 degrees.
I would recommend the manual valvebody on the TH350 because it assures you that your at maximum line pressure all the time. It also does away with the governor and the vacuum modulator. Less to go wrong.
Old Nov 1, 2005 | 04:53 AM
  #33
LS13RDGEN's Avatar
What flywheel did you guys use? One from a TH350 or the stock LS1?
Old Nov 2, 2005 | 10:45 AM
  #34
Reject's Avatar
subscribing...
Old Nov 2, 2005 | 09:16 PM
  #35
Steve Burger's Avatar
LS1TECH Sponsor
I used the TCI SFI FW on mine. I also converted from and M6 th a TH350. Speed did the tune and the VSS is dead on. There are a few issues with converting to a pure M6 PCM program. The Skip Shift, Clutch Switch, and Backup Lights codes wil need to be deleted. I have the SES light on all the time due to this. Speed is going to tune these out.
Old Jan 1, 2007 | 07:14 PM
  #36
pirate3's Avatar
good post. This is my next mod.
