old school transmission question
You can take a th350C which is a lock up trans and convert it to non lock up with a pump, input, converter, and a shift kit that has instructions for the valve body/pump mods.
You can also do it with 4L60's by using a non lock up valve in the pump and a converter with no lock up clutch. The valve and the non lock up converter must be used together.
