converter
Old Feb 8, 2005 | 04:06 PM
scotts94_z28's Avatar
Default converter
im thinking about putting a stall converter with a speed around 3000-3200 rpm's and i was wondering how exactly they work. If im at the strip does it mean i can push down the brakes and bring the revs up to that speed? any info would be appreciated
Old Feb 9, 2005 | 09:38 AM
any one know?
Old Feb 9, 2005 | 10:43 AM
Muerte_X's Avatar
Yes, provided the tires can hold it. They also do much more, try doing a search, there's a ton of info on this site on them.
Old Feb 9, 2005 | 11:20 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
It does vary from one converter manufacturer to another, but the rated stall speed of a torque converter will typically not be achieved by brake-stalling. To achieve the true stall speed of a torque converter, you would need to have a trans brake. Every converter does vary according to what type of launch technique they prefer, though, for best 60'. I know the TCI converters usually like to be brake-stalled to 1800-2200 RPM, at least for the larger ones. A Street Fighter 3000 might work better with a little less brake stall since it is a tighter converter. When you launch, the converter will normally flash 100-200 RPM higher than its rated stall speed.
I've tried 13 different converter and numerous brands in LS1 vehicles, so feel free to give me a call or shoot me an e-mail at trevor@texas-speed.com if you have any questions. I'll be glad to help you select the right converter for your application.
Trevor
Texas Speed & Performance
__________________
