Th350
Old Feb 8, 2005 | 07:49 PM
LS1 Brent's Avatar
Default Th350
I'm looking at getting a th350 for my car but I don't know where to start looking? If i end up buying one used from here, what all do I need to look for to do the swap? Thanks alot.
-Brent
Old Feb 9, 2005 | 12:47 AM
GPowrie's Avatar
Crossmember, dipstick, drive shaft, shifter, converter, and trans cooler. That is the basics. You will need to come up with lines, the stock can work but need to be modified.
Old Feb 10, 2005 | 03:41 PM
396D1SS's Avatar
you can use the stock shifter and if you use a 9" tailshaft on a th350 you can keep the stock driveshaft
Old Feb 12, 2005 | 09:41 AM
Strokinit383's Avatar
check this out. might make things easier.
http://www.bulkpart.com/Merchant2/me...y_Code=Teckpak
