TCI th400 and speedometer sensor
Old Feb 18, 2005 | 04:03 PM
Juicedz's Avatar
Default TCI th400 and speedometer sensor
I have a 95 camaro going from an m6 to a th400. Some guy at tci told me that i couldn't make my speedometer work after I did the swap. any idea? part numbers, etc?
Old Feb 18, 2005 | 11:01 PM
Juicedz's Avatar
any body? to the top
Old Feb 19, 2005 | 12:59 AM
Smitty's Avatar
Use the sensor & reluctor ring that came on SS454 pickups that came with TH400's.
PN 8655291-speed sensor & PN 8655315-reluctor ring.Then with edit go to speedometer>speedometer input>pulses per mile and adjust the pulses per mile to match your rear gear/tire to get the speedo correct.Look at the ABS wheel speed sensors to get your correct speed going up the road.
Old Feb 20, 2005 | 02:51 PM
MakoLS1's Avatar
What he said!
Old Jun 29, 2005 | 05:02 PM
GTS346's Avatar
Will these parts work on a TH350?
Old Jun 29, 2005 | 05:53 PM
SUX2BU's Avatar
Or you could do it for free and just plug your speedo sensor into one of your wheel sensors. prefferably the front so it doesn't change when you put different tires on the back.
Old Jun 30, 2005 | 04:52 AM
GTS346's Avatar
My setup is for a 70's car conversion, can I adapt a wheel sensor?
I do not need it for a digital dash reading as I still retain my speedo cable, I just need it so the PCM see's a signal and the car doesnt stall.
