4l60e v8 to v6
Old Feb 27, 2005 | 09:32 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default 4l60e v8 to v6
will a 4l60e from a v8 directly swap to a 4l60e from a v6 3.8 98 camaro? same spline convertors,sensors?
Old Feb 28, 2005 | 09:34 PM
John_D.'s Avatar
Far as I know, everything is the same except... the bellhousing bolt pattern. If you have a removable bellhousing, you should be able to swap those.
