Need to know what stall to run
Old Mar 7, 2005 | 08:47 PM
Bagg'd99's Avatar
Default Need to know what stall to run
Here's the specs on the motor 99 Silverado Ex-Cab SB 5.3 Whipplecharged, Westers Whipple tune, 42lb injectors,80mm BBK, 212/221 @.050 w/ .510/.510 lift and 114LSA, 1.7 Crane roller rockers, Doug Thorley Tri-Y's, K&N open air, Walbro inline pump. Need to know what size stall to run on it. I should be atleast 475+ HP at the crank
