need help po758 codes
Old Mar 13, 2005 | 12:58 PM
Rays C5's Avatar
Default need help po758 codes
I'm so over this.... I now have codes p0758 2-3 tran solenoid. Car not in or taking of in 1st gear. Other issue p0522 low oil pressure circuit. Gauge register zero. On the p0522 issue I noticed when I cleared the code the gauge went to 40psi then back to zero. This is driving me nuts.Have ls1edit and atap and never had these problems before.FWIW had to get pcm flashed bask to stock but put modded program back in after car started and drove it for 45 mins. Any help on these code and what was done to correct this????
Old Mar 13, 2005 | 05:48 PM
Rays C5's Avatar
any info???
