I'm about to install BMR torque arm.Help!
Old Nov 28, 2001 | 06:33 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Default I'm about to install BMR torque arm.Help!
I am hoping someone might have some tips , install steps, pointers or even pics to help me out. It doesn't look too complicated. I'm a little concerned about adjusting the pinion angle. Any one? Thanks.
Old Nov 29, 2001 | 12:39 AM
SteveD's Avatar
Default Re: I'm about to install BMR torque arm.Help!
Installing the torque arm is really easy. Get the car as high as you can. The job is alot easyer to do on a lift. Bolt everything up in the front first. It is going to take two people to do the job. You will need a hammer to move the rear bracket around when you slide the bolts through. Be conservative on the pinion angle. I went a little to far and now have loose ujoints. Take your time and get everything tight. I would not go more than 2deg's on an A4. Let me know if I can help.
Steve <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 30, 2001 | 11:15 AM
DARK AGE 53's Avatar
See if this can be of any help, http://www.bmrfabrication.com/instructions/ta001.htm .
Al
