Installed stall converter, now leaking?
Can a bad stall converter cause a leak? or is it just because the shop didn't seal it right? I am hoping the converter isnt the problem, I would hate to shell out another 600 bucks for another
Good Luck
probably the front pump seal- problem is the trans has to come back out to fix it but it isn't hard to replace and i don't think it is too expensive of a part. i will be replacing mine soon (trans is coming out anyway) just for piece or mind, i had some minor leakage on the bottum of the bell-housing last time i looked...
Good Luck
Try $9.16 clip at the dealer. I bent one last weekend and had to replace it. Went to the dealer and about passed out when he told me how much they were. I bought 4 to keep in my tool box for those "just in case" times.
