Need Help Fast
Old Apr 2, 2005 | 02:51 PM
joshluther's Avatar
Default Need Help Fast
I have a 2004 Silverado with a 4l60e with a Trans Go SK4l60e-l shift kit. Today I manually shifted into 1st, 2nd, 3rd then the shifter wouldn't move into overdrive. So I get home and put the truck on the lift disconnect the cable and the problem is in the trans. I drop the pan and fiddle with the linkage and it works now. The problem is there was a check ball in the pan. The truck always shifted fine. I don't think I dropped the ball when I installed the shift kit. The ball that you stick in the case is still there so it leaves one of the valve body ***** It would be tough to drop one of those. Could it have fallen out during the dissasmbly for the shift kit? It says 7 ***** on the plate and 1 in case for reassembly is the same as stock?
