Re tune needed when going to a higher stall
Old Apr 6, 2005 | 03:32 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Question Re tune needed when going to a higher stall
Hi everyone;
I have a Y3000 2.0 STR installed in my 01 Z28 coupled to 3.73:1 rearend gears. I have had the vehicle professionally dyno tuned for the TC change
(i.e. TM deleted, shift points adjusted etc). The vehicle runs wonderfully, however I am starting to want more stall.
If I replace the TC with a 3600 stall, 2.5 STR, would I need to have the vehicle re dyno tuned?, or would all the necessary adjustments been done with the initial dyno tune?
Thanks in advance.
SteveC
Old Apr 6, 2005 | 06:04 PM
Blacker's Avatar
You should be fine. I had my transmission shift firmness and shift points adjusted with a 3000 Stall. I upgraded to a 3600 stall and did not need to make any changes.
Old Apr 6, 2005 | 08:19 PM
Pewterpower's Avatar
I went from the stocker to a Vigi3600 and did not need a tune. I also did a shift kit at the same time. I did however go back later and had my shift points adjusted. Most of the time its not necessary, but sometimes it is.
Old Apr 6, 2005 | 10:03 PM
RevGTO's Avatar
Pontiacerator
Get it installed and see how it works for you. You might decide you want to tweak it here and there, but I can't imagine you needing a dyno tune.
Old Apr 8, 2005 | 08:41 PM
CamaroCain's Avatar
I would get it retuned if I were you, but dyno tuning is not needed. I would recommend tuning it on the street if you can.
Old Apr 14, 2005 | 02:46 PM
SteveC's Avatar
Thanks so very much for the input.
SteveC
