Need Tranny Temp Options...
Old Apr 6, 2005 | 05:31 PM
Kenafin_02TA's Avatar
Default Need Tranny Temp Options...
I'm having problems with hot tranny temps...during the winter by the time I'd get home she'd be usually around 180*. Now that the warmer weather is here she's anywhere from 200*-210* (not good...)...and with warmer weather still to come, I'm not looking forward to even higher tranny temps and a cooked tranny. Of course the aftermarket stall doesn't help tranny temps any...but I've got a large Hayden tranny cooler on the car and a deep tranny pan. (The cooler is mounted flush against the radiator, not "dope" style.) What other things can I do to try to keep the tranny cooler? I've heard of some people running two tranny coolers. I also know they sell tranny coolers with fans on them or you can mount a fan on an existing one. Are there other options? How well does the two tranny coolers work? What about the fans?
Another idea that I read was that after someone installed a 160* thermo and adjusted their fans, they were seeing cooler tranny temps as well. Does this seem possible to anyone?
Old Apr 6, 2005 | 06:02 PM
Blacker's Avatar
Lowering your fan temps will help. I an running a SS4000, B&M 24,000 GVW Cooler, 160 Thermostat and adjust fan temps. I run no higher than 180* in hot weather and in city driving. 1 cooler is all you need to keep the transmission cool.
