Post DIY Eibach install: The front feels too solid....help me!
Old Dec 10, 2001 | 07:57 AM
JC's Avatar
JC
Default Post DIY Eibach install: The front feels too solid....help me!
I basically tightened the front sway bar till it was VERY tight. Was that wrong? The front has almost no give. Is the sway bar the prob? I'm going to loosen it today.
The install is a pain (first time) I only had time to drop the front. I'll do the rear today.
Old Dec 10, 2001 | 09:47 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Post DIY Eibach install: The front feels too solid....help me!
Moving to suspension section <img src="images/icons/smile.gif" border="0">
Old Dec 10, 2001 | 08:34 PM
Chris Spiess's Avatar
What to you mean you tightened it til is was rally tight? Are you talking about th end links? They should be tightened unthi the bushings start to compress a bit. You might want to consider getting a set of shorter end links to get the swaybar geometry back in order. Which Eibachs did you install? i have sportlines and they are really stiff so there isn't much movement, and since they're so much lower the bottom much easier.
Old Dec 11, 2001 | 08:53 AM
JC's Avatar
JC
I loosened the endlinks yesterday and it helped somewhat. It seems like there is some type of knocking when going over a bad road. Maybe something is loose? NE way. Where can I get some shorter end links?
I installed the pro-kit on the front. Haven't done the rear yet.
