Flexplate differences?
Old Apr 19, 2005 | 08:46 PM
Slow Z28's Avatar
Default Flexplate differences?
alright, just was looking on summitracing's website since i need to order a new flexplate for the TH350 conversion. anyways, i have two part numbers
TCI-399173 that is $99.99 and is listed for a 4L60E
then there is
TCI-399753 that is $199.99 which is what i come up with for a '99 5.7L engine
what's the $100 difference gonna be for? both are SFI approved and for a one piece rear main seal. i've always seen the $199.99 version and was just checking shipping date/availability. Wouldn't mind saving $100 if it was gonna work just as well.
Chris
EDIT - cheaper one is externally balanced. both are 153 tooth, but the ATI flexplate on the ATI's website for LS1's is listed as a 168 tooth. now there's another question! what tooth count? haha
Old Apr 20, 2005 | 07:25 AM
BTL FED's Avatar
then there is
Chris
The Ls1 is 168 tooth count, the tooth count is the number of teeth on the outside of the flexplate, it is how the starter turns the motor over. The 99 dollar one is for a Lt1, the 199 one is for a Ls1.
Old Apr 20, 2005 | 10:20 AM
Slow Z28's Avatar
ok, guess i just need to call an LS1tech vendor instead of going through summit to make sure i get the right one. thanks for the info!
Old Apr 20, 2005 | 12:03 PM
strokedls1's Avatar
I just called tci direct to get the info. Just installed the flexplate and it is real beefy. It is thicker than stock. It has dual pattern holes for ls1 converter or sbc converter.
