1st to 4th?
Old Apr 22, 2005 | 10:37 AM
Semp3rFi's Avatar
Default 1st to 4th?
Hey, Ive been hearing rumors that on manual TransAms they skip a few gears and shift straight into 4th? Is that true, or just a rumor? If it is true, is just better than to race shifting up manually rather then letting it go auto?
Old Apr 22, 2005 | 11:42 AM
8-Pack's Avatar
Yeah its called CAGS, computer aided gear slection. It locks you out of 2nd and 3rd under light acceleration.
Old Apr 22, 2005 | 11:44 AM
blkZ28spt's Avatar
The manuals come with a skip shift program to meet fuel usage requirements. If you arne't into the gas very much it will force you to go from 1-4. If you give it any real amount of gas you can go to second. It is very easily deleted. I don't get what you are sayign when you ask if it's better to shift manually than let it go auto. With a manual there is no letting it go auto option. On the auto cars you will always go 1-2 and should not shift it manually to race.
Old Apr 22, 2005 | 02:04 PM
Semp3rFi's Avatar
on my car, its an automatic, but I can put it into 1st, 2nd, 3rd, and then Drive(Im guessing thats 4th)
Old Apr 22, 2005 | 04:50 PM
blkZ28spt's Avatar
With an automatic just leave it in OD and call it good. The 1-4 and all that junk is only with M6's. In the auto third (D) is 1:1 and fourth (OD) is overdrive.
Old Apr 22, 2005 | 05:19 PM
02WS6Bird's Avatar
chances are your shifter reads
P or P
R or R
N or N
D or OD
3 or D
2 or 2
1 or 1
It doesnt skip anything-both of the ways shown are the gears 3 or D will shift 1st-2nd-3rd gear-abnd for D or OD itll shift 1-2-3-4
3 or D is a 1:1 ratio and D or OD is like a 0.5:1 or something like that if you have a Bird "D" is overdrive goes throuigh all 4 gears and if you have a camaro "OD" is Overdrive
On a Bird "3" is drive only goes up to your 1:1 gear and in a camaro "D" is the drive gear only goes to your 1:1
now 1st and 2ns both mean it starts off in that gear for newer ones i believe its 99/00-02 where it starts AT 2nd gear if the shifter is on 2-rather then 98-99(?) shifted 1-2 with the shifter at 2
Its really weird just leave it in D-bird or OD-camaro or leave it in 3-bird or D-camaro all depends on situation fuel economy consern go witht eh 1st choiice
Old Apr 28, 2005 | 10:34 AM
Semp3rFi's Avatar
Thanks for the help man!
