Two questions...
Old Apr 26, 2005 | 06:18 PM
Slow Z28's Avatar
Default Two questions...
First, Part number for arp converter bolts for TCI flexplate/LS1, does anyone have this? i can't seem to find it anywhere
Second, what size AN fittings could i use on a TH350 to run braided line to the tranny cooler? What size goes into the transmission, and can they just be screwed in? Thanks
Chris
PS - anyone run a tranny cooler with the braided line up to the front and then back? how much line did you use and what size?
Old Apr 27, 2005 | 11:17 PM
CamaroCain's Avatar
as far as the bolts go, TCI might be able to tell you exactly what you need.
Old Apr 27, 2005 | 11:40 PM
Slow Z28's Avatar
got the flexplate bolts
and i got the tranny today and it already had the AN fittings in it so i only need the female end and braided line.
thanks !
