vigilante bolt length PLEASE
Old May 6, 2005 | 07:18 PM
redbandit98's Avatar
Default vigilante bolt length PLEASE
hey everyone...i need to know what size bolts the vigilante converters come with..i mean as far as length goes..if anyone has any laying around or a new converter with the bolts still in the wrapper would you mind measuring them for me? i bought a used vigi converter and my stockers are too long...i want to go buy some bolts the correct length instead of cutting up my stockers (also wanting regular bolts instead of allen head bolts is another reason im buying new ones) sooo..if anyone would be so kind as to measure them i would grealty appreciate it.i would call vigilante but its friday and im sure they dont work on the weekends..thanks matt
Old May 6, 2005 | 08:16 PM
Tiger2o69's Avatar
I would like to replace my cut off stockers with some grade 8's but I didnt know the right size either.
Old May 8, 2005 | 07:47 PM
BLWN1's Avatar
I need this info too if you find out...
Old May 8, 2005 | 11:17 PM
strokedls1's Avatar
I believe mine were a 10mm with 1.5 thread width and 15mm long. They are grade 8 bolts. If your using a stock flex plate those will work. I will try to finf them and give an exact length for sure.
Old May 8, 2005 | 11:28 PM
strokedls1's Avatar
I measured one and it is 15mm.
Old May 8, 2005 | 11:36 PM
Tiger2o69's Avatar
thanks
