Soft 1-2 need advice
Old May 13, 2005 | 04:54 PM
99SSLS1's Avatar
Default Soft 1-2 need advice
I had the car tuned and the 1-2 shift got soft at wot. The 2-3 improved nicely but the harder you get on it in first the softer it shifts. I want to just firm up the 1-2 and was thinking of just shiming the 1-2 spring or maybe changing to the vette servo. I don't really want to do a full shift kit if I don't have to. The tuner said he up the pressure as much as you want with a a4.
Any advice.
Eric
Old May 13, 2005 | 05:46 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Smile
Any advice.
Eric
I went with the Superior billet super servo (2-4), and it firmed up my 1-2 shift over my stock vette servo on my 01 Z28.
SteveC
Old May 13, 2005 | 05:57 PM
99SSLS1's Avatar
Just by changing the servo only? Where did you buy your servo?
Eric
Old May 13, 2005 | 06:29 PM
jxaxsxoxn's Avatar
Don't get a super servo, your car should have a vette servo. If it's shifting soft with that you have a problem somewhere. Don't just cover the problem up.
Shimming the accumulator will effect low to part throttle too and that can be annoying plus it probably won't solve your problem.
You need to find out what the guy who tuned it did.
Maybe the extra fluid pressure broke the accumulator piston.
My 1-2 has always been firm, maybe the tuner thought ahead and knew more line pressure would make the 1-2 too harsh and tuned 1-2 down too far.
Who knows, thats why you should start with him.
Old May 14, 2005 | 07:59 AM
SteveC's Avatar
Smile
Eric
I also had a Transgo shift kit installed. I purchased the 2-4 servo from the shop that did the TC change.
Summitt Racing sells a billet race servo, it is in the section with the performance TC.
Sorry for any confusion.
SteveC
