torque converter for daily driver?
Old Dec 26, 2001 | 02:28 PM
2000LS1Z28's Avatar
Default Re: torque converter for daily driver?
[quote]Originally posted by Dave Jones:
<strong>
What's an RSA?</strong><hr></blockquote>
The RSA's are the crappy lowest-level stock tire your car receives from the factory(with 2.73 gears I think). In other words, they are TERRIBLE for traction(even with the stock converter). Just get the Nitto DR's with the Vigilante 2800 and your car will be a monster down-low.
Mike
Old Dec 26, 2001 | 02:40 PM
Dave Jones's Avatar
[quote]Originally posted by 2000LS1Z28:
<strong>
Mike</strong><hr></blockquote>
They are Goodyear Eagle 245/50/ZR 16's. I don't think they are bottom of the line, but they are definitely not sticky. They also seem to flex a bit much on the turns. That could be the car, though. I'm going to install DD subframes next.
The speedo goes to 155, which I presume means the stock tires are rated for that speed.
How do the Nitto DR's handle on the twisties? Do I want the P245/50/R16 96V Nittos?
Old Dec 26, 2001 | 07:01 PM
Ragtop 99's Avatar
Dave there are 2 "performance" tires for the Z28. Eagle RSAs are all weather and Eagle GSAs are summer tires. Look at the sidewall of your tires.
The Nitto drag radials do quite well in the twisties when the pressure is kept up around 28 - 30 lbs.
Old Dec 27, 2001 | 03:03 AM
TR's Avatar
TR
"...So a ST 3500 would be good for my daily driver/drag racer?..."
Sure, if you like driving around town in 3rd gear to avoid setting the P0757 SES code that the ST3500 seems to be in love with.
Dave, don't forget a trans cooler to go with any converter you install. Very inexpensive insurance!
Old Dec 27, 2001 | 03:54 AM
TransAm2002's Avatar
Go with the ST-3500!!! I love mine. <img src="gr_grin.gif" border="0">
Old Dec 27, 2001 | 09:26 AM
Supertrapped's Avatar
Speed freak
[quote]Originally posted by TR:
<strong>
Why do you drive around in 4th around town anyway? There is no point to it. On automatics, you actually don't need 4th until you're doing 55mph+. Just a thought.
Miah
Old Dec 27, 2001 | 10:55 AM
Stab & Steer SS's Avatar
TransAm 2002 have you had any problems in your 02'.Setting codes sticking solinoids etc?
Chris
Old Dec 27, 2001 | 11:06 AM
Red 99 TX SS's Avatar
Here's my 2 cents worth. I have had the Yank 2600, ST3500, ST3000, and will soon be getting the Stealth 3200. The Yank 2600 feels like stock at part-throttle but give a little extra boost at WOT. The ST3500 and ST3000 are too loose at part-throttle IMO. The small diameter of the converter makes it feel loose at anything below the rated stall speed. I will soon get a Stealth 3200 since, according to Mike at Yank, it feels like stock around town since it is close in size to the stock converter, but at WOT it will really take off. Hopefully it will not set off the codes that the ST3500 and ST3000 did.
As a side note, at least here in Texas, starting May, 2002 an SES light will cause you to fail emissions testing. The LS1Edit currently does not have the capability to turn off these tranny codes. I have Emailed the makers of the LS1Edit, and asked them to consider adding those codes to the list that can be deactivated. Otherwise, these tranny codes could become an issue depending on where you live and how picky they are about the SES codes and emissions testing.
[ December 27, 2001: Message edited by: Red 99 TX SS ]</p>
 Michael S. Palmer
Old Dec 27, 2001 | 11:51 AM
FormulaWS6's Avatar
ST 3500 in mine with 3.23 gears and a tranny cooler. Have had it for around 5 months. It is also my daily driver. NO SES CODES ever. So far, it dropped my time by .7 while the BFGs were sliding. Next time, I will have some ET Streets...
[ December 27, 2001: Message edited by: FormulaWS6 ]</p>
Old Dec 27, 2001 | 04:48 PM
WILWAXU's Avatar
Umm, for the naah sayers. If the same converter throws codes only in 2001 & up f-bodies and not older ones... is it the converters fault?
Old Dec 27, 2001 | 07:24 PM
Mr car's a 1999 and it throws codes with the super thrusters but not the Yank 2600.
Old Dec 27, 2001 | 07:38 PM
  #32
MitchR's Avatar
[quote]Originally posted by WILWAXU:
<strong>Umm, for the naah sayers. If the same converter throws codes only in 2001 & up f-bodies and not older ones... is it the converters fault?</strong><hr></blockquote>
John, I love my ST3500 but in all honesty, I never hear any of the Vig 3200 owners having the same issue with the same code. Now that may be because there are few or no 01/02 LS1's with a Vig 3200 (I doubt it though) OR the Yank is designed in such a way that it maximizes performance in every way so much so that it is on the edge of incompatibility with some of the newer LS1's programming. I personally don't mind because of the great performance and I'm used to having high performance parts cause some loss in driveability or comfort. Hopefully LS1 Edit will be capable of adjusting for the shift solenoid problem.
Just some thoughts.
- Mitch
Old Dec 27, 2001 | 07:58 PM
  #33
Slow Z28's Avatar
no codes here with the Vig3200 <img src="gr_stretch.gif" border="0"> although i would have like the higher STR of the ST3500
Chris
Old Dec 27, 2001 | 08:37 PM
  #34
EvilLS1's Avatar
No codes with my ST3500 either.. And it dropped 6 tenths off of my best ET with the TT2800! So it wouldn't suprise me if it droped the ET by a full second on a car with a stock converter. The ST3500 kicks *** IMO!
Old Dec 27, 2001 | 08:49 PM
  #35
WILWAXU's Avatar
[quote]Originally posted by MitchR:
<strong>... Hopefully LS1 Edit will be capable of adjusting for the shift solenoid problem.</strong><hr></blockquote>
I should know by the end of next week, what Ed wright can do <img src="gr_images/icons/wink.gif" border="0">
I honestly think the solenoid problem is a line pressure issue. Since I installed the Yank tranny I haven't had it again.
All of my issues are to with TM, and I think the line pressure issue (soleniod) is directly related to TM.
