torque converter bolts sheared!!!
THANKS
Unless they are the allen head type.
You can find replacements in the MotorMite Help section of most auto parts stores.
FWIW I've used grade two (no marking) 3/8 bolts on a th400 converter that used nuts and bolts in a one ton truck. In other words they don't have to be super strong. Grade 8 would be fine, or 9.8 metric.
Just be sure on the length, too long is almost as bad as too short and I doubt the hardware store will have the exact length, so you might need to cut them.
10.9 is a pretty strong bolt, maybe equal to a sae grade 8.
