ss 3600
Old May 23, 2005 | 08:02 PM
snowedz06's Avatar
Default ss 3600
I was wondering how this converter works on a 150 shot is it safe and does it have 6 mounting lugs .
Old May 23, 2005 | 08:11 PM
Roarin_8's Avatar
Could have sworn that it has 3 mounting lugs. I know that my SS3800 has 3.
Old May 23, 2005 | 08:20 PM
02 Pewter LS1's Avatar
It has 6 mounting lugs but you need to change your flywheel out because it only has 3 mounting lugs. Yes a 150 shot is safe with this converter.
Old May 23, 2005 | 08:25 PM
snowedz06's Avatar
sweet looks like ill place the order thanks
Old May 23, 2005 | 08:27 PM
You can still use your stock flywheel and use only 3 bolts or if you want all 6 bolts then you buy a new flywheel. It is a kick *** converter. Just have some good tires for it.
