Yank Converter???Help???
Old May 23, 2005 | 10:51 PM
JJ_TURBO's Avatar
11 Second Truck Club
Default Yank Converter???Help???
Does anybody knows by looking at the sticker in this converter for what set up is this converter for??? It was suppost to be for a 6.0 and 4L80-E setup but the damn thing does not alline right or something. I have my truck at Allen Nelsons place and I can't get it back cause of this problem. Unless I get a new converter.
Old May 24, 2005 | 07:38 AM
Yank's Avatar
You must of got it used!
as the label shows to be rebuilt Pro yank 3400 in early 05
You must redrill the flexplate to get that special converter to fit your truck as it has the LS-1 bolt pattern
Old May 24, 2005 | 12:42 PM
JJ_TURBO's Avatar
Allen got a special plate from TCI and that works now but the problems seems to be on the dowel is too short and won’t reach the crank/spacer/flywheel. Allen try it in many ways by using the spacer and without and didn't work.
