3600+ stall
Old Jun 8, 2005 | 05:41 PM
conv69SS1's Avatar
Default 3600+ stall
Quick Question?
I just put a 3600+ stall in my turbo 350 trans and it doesnt it as hard in second gear is this the norm?
Old Jun 8, 2005 | 05:45 PM
blkZ28spt's Avatar
What do you mean by it doesn't hit as hard in second gear? Nothing will accelerate as hard in a higher gear.
Old Jun 8, 2005 | 05:58 PM
conv69SS1's Avatar
Before the new stall when I hit second it would blow the tires off and get kinda side ways now I dont think it even spins the tires which i guess is a good thing
Just want to know if this is because the looser converter and its norm.
Old Jun 10, 2005 | 12:36 AM
deetsnai's Avatar
my friends did the same thing, the 2nd gear actually pulls a little less hard cuz the converter is looser
Old Jun 11, 2005 | 02:10 AM
Raptor99's Avatar
You could have a pretty big difference in stall ratio's. If I remember correctly, that's the most important thing for judging how hard she'll hit
Old Jun 11, 2005 | 09:49 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
A high stall will soften the shifts without my 3000 stall in my tranny the back of my truck would move sideways when it shifted and barked the tires and now it just chirps them a little and hauls ***. This is perfectly normal with a high stall. I thought the same thing as you but the guy that built my tranny said a high stall will soften the shifts quite a bit and there was nothing to worry about. I have over 5000 miles with the stall and built tranny setup and no problems even being reterded towing 6200#s and flooring all the way through second and damn near boiling the tranny 230* on a 60e isnt good.
Old Jun 11, 2005 | 11:58 AM
conv69SS1's Avatar
Thanks all for your input, just wasn't sure if the conv. was working right thanks again
Old Jun 11, 2005 | 05:05 PM
black 2001Vette,Nightmare's Avatar
When my tranny shifts into second, it's like being hit in the back by a 350lb Pro football player!!! I have a 3200 Vig...but I also have a tune and higher line pressures, which make a LOT of difference I guess.
Old Jun 11, 2005 | 10:33 PM
conv69SS1's Avatar
no line pressure adj. in my Th 350 but thanks
Old Jun 13, 2005 | 04:47 AM
Automatics's Avatar
Restricted User
If you are talking about the 1-2 shift at WOT, then the design of the torque converter & the diameter of the TC will have a big effect on this. The torque converter should multiply torque, and produce a somewhat smooth shift and not a "violent" shift. If the transmission shifts to hard, regardless of the torque converter, then the transmission (transmssion shift firmness) needs to be addressed first.
Old Jun 13, 2005 | 11:19 AM
conv69SS1's Avatar
before the car had a 11 inch converter 2100-2700 stall it now has a 9 inch stall 3600+ before I switched the stall it shifted very hard and now it seems to just kinda slip into 2nd with only a slight chirp of the tires.
