restalling a stock converter
Old Jun 12, 2005 | 08:06 AM
02chevyracing's Avatar
14 Second Truck Club
Default restalling a stock converter
can you restall a stock converter up to 2800? i just bought this restalled converter and the owner sayes it constantly flashes around 2800 with his 4.8, i was thinking since i had a 5.3 it would flash about the same rpms or a little more thanks for the input Gene
Old Jun 12, 2005 | 08:19 AM
electricz28's Avatar
put your trans in 2nd. hold the brake and gas it, this will give you an stall speed-rpm
Old Jun 12, 2005 | 09:49 PM
but can a stock converter be stalled that high?
Old Jun 13, 2005 | 12:48 PM
I think it could happen if the right stator and turbine combination are used. IMO buy a used verter with the stall you desire and have it cut open and checked out. That way you can dump that huge 11" anchor.
