SY3500 Questions
Old Jun 12, 2005 | 04:16 PM
BLOODTA's Avatar
Default SY3500 Questions
I need some info on the Super Yank 3500. First it will be 98% street driven, will street tires be fine? Second, how much does it cost to have it restalled?
Thanks,
Tony
Old Jun 12, 2005 | 08:32 PM
BAT TA's Avatar
Active Streak: 30 Days
I was researching converters last fall I almost got an sy3500. It's made to use with street tires hence the low STR (1.7ish, i think) so you'll be fine. As for how much it costs to restall, you might want to contact yank about that one.
http://www.converter.cc/
Old Jun 12, 2005 | 08:43 PM
Ragtop 99's Avatar
It is perfect for a street car on street tires.
You can get it bumped as high as a 4000, but it will cost you several % in efficency.
Old Jun 13, 2005 | 12:25 PM
FACE's Avatar
IIRC, it'll cost around $200 for a restall.
As far as the SY3500 itself, it's a great street converter. I was also able to cut some 1.7's with it at the track.
Old Jun 13, 2005 | 03:00 PM
XTrooper's Avatar
It's an outstanding street converter and is awesome from a roll.
Also, as already stated, with drag radials you can cut consistent 1.70s and occasional 1.60s with it at the drag strip.
P.S.- This converter loves 3.73 gears. You may want to consider a gear change in the future.
