Best way to keep your tranny in good shape!?
change the fluid often....maybe none in the winter but 3 times from spring to fall. (racing time)
NEVER get on it with tranny temps over 200
At the track i pull the shifter down to first...launch and then move it straight up to OD.
I never do a 4-3 or 4-2 wot downshift. I hit the gas enuff to get it to drop a gear and THEN floor it.
Pulling it down to 1st on launch DOES engage SOMETHING else....tranny guy will have to tell you what. My builder, RockOn transmissions told me to do this. I forgot once and while stalling it up, remembered...pulled it down to 1st and felt the car lurch forward some like it had more clutches or something so I know SOMETHING is there.
In your opinion what would be the best way to go about a freeway roll. Should it just be avoided flat out, or could you drop the shifter down to 2, punch it, then slid it back up to D or OD?
Sorry. Not so smart...
Rock On tests their trannys on a tranny dyno...thats how its supposed to be done!!!
