Y3000 and my 3:42's
Old Jan 6, 2002 | 05:00 PM
Spade's Avatar
Default Y3000 and my 3:42's
Will this be a good combo for street and track. I drive on the street 90% of the time so I do not use or ever will use DR's. Just need some opions. Thanks <img src="gr_images/icons/wink.gif" border="0">
Old Jan 6, 2002 | 06:49 PM
DanZ28's Avatar
Default Re: Y3000 and my 3:42's
That's actually a good all around street setup. Did you have the 3.42's installed? What year is your car? DR's would sure help at the track <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Jan 6, 2002 | 06:52 PM
LS1powerN20's Avatar
that sounds like a good setup, it'll work nicely.
Old Jan 6, 2002 | 07:46 PM
Spade's Avatar
Got a 98Z. Purchased the car used about 2 years ago and it already had the gears in it. Previous owner just got the whole rearend from a M6 and put it on the car.
[ January 06, 2002: Message edited by: Spade ]</p>
Old Jan 6, 2002 | 10:03 PM
Ragtop 99's Avatar
Its a good street converter and will get you decent track results. You feel a major improvement.
If drag radials are definitely not in your future, a SY 3500 is the way to go. The 3500 stall and low STR will be a bit looser than the Y3000, but it is the easiest converter to launch hard on street tires.
Old Jan 6, 2002 | 10:37 PM
Spade's Avatar
[quote]Originally posted by Ragtop 99:
<strong>Its a good street converter and will get you decent track results. You feel a major improvement.
If drag radials are definitely not in your future, a SY 3500 is the way to go. The 3500 stall and low STR will be a bit looser than the Y3000, but it is the easiest converter to launch hard on street tires.</strong><hr></blockquote>
I was looking at that converter also but I just cant seem to spend that much more for that converter.
