Gears OR Stall?
Maybe I just say that because I did a converter first and gears later, and dont know how much of a difference a gear swap can make by itself. I know from stock-> converter and then later on doing converter->gears, the gears made more of a difference IMO.
If you've got 3.23s it's a no-brainer, converter all the way (3500 minimum). I just HATE 2.73 gears.
Seriously though, a lot of Mustang guys (myself included) do gears before the converter. But it seems that most of y'all on here have done it the other way around. After seeing how all of your cars have responded to the converter, I think he should go with it before the gears.
What up cuz?
I'm one of the 2.73 Z28s.
My converter will fix that though, and after that down the road I'll put in some 3.42s
i never knew
If that's true, then I've seriously NEVER heard of an auto having 3.42s from the factory.
Are you sure about that? Maybe it was an M6 and got converted to an auto https://ls1tech.com/forums/showpost....85&postcount=7
Small cam IMO means more low-end torque ... so, wouldn't do anything over 3.73's with my current cam. It's a baby.
I see a TC in my not to distant future.
It's been two years and I've never been able to get to the track to take her down the 1/4! I'd love to get there this week though to see how she does before the converter goes in. If not, then I'll just try to get it in and hit some mid 12s.
Good luck with your header install!Oh and if it helps at all, with my current setup I dynoed 338 rwhp/345 rwtq on a fairly hot and humid day.
