transgo vacuum mod
Old Jul 23, 2005 | 07:46 PM
transamgod's Avatar
Default transgo vacuum mod
I just got a flp level 4 tranny 4l60e with a transgo vac mod port on it. my question is where does this tie in and what type of hose do i use?
Old Jul 24, 2005 | 12:11 AM
Dmoney's Avatar
If the port is there, then they should have given you the neccesary hardware to complete the install, and if they did in fact install the modulator. There should have been a clear hose with a spring like hose inside the clear one and a 'T' connector to hook up to the brake booster line.
