what do you think of this converter/gear combo
98 ta a4...... bone stock
3.42 gear with a yank 3200 on some 26 10.5 15 et streets, and perhaps a nx 150 shot????
any suggestions will be appreciated....
thanks
james
thanks
james
The gear choice IMO is good, but converters are expensive... and if you're going to throw around $700 on a converter... do it right the first time. Often people buy a lower stall thinking a 3500 will be too much and end up dissatisfied and wanting more stall.
Someone gave me some good advice when I was converter shopping...
"Get the next higher stall than you think you can handle" -- that was very good advice.
I got an ST3500 the first time around and after a little adjusting to the different drivability and I couldn't be happier!
Agree with monster; get the ST 3500. It is a good nitrous converter and will give you better NA times too.
What gears do you have now? I would not switch from 3.23s to 3.42s - its not really worth the investment. From 2.73s, it is fine.
