99 C5 4l60E help!!!!!
Old Aug 14, 2005 | 09:32 PM
99SilverC5A4's Avatar
Default 99 C5 4l60E help!!!!!
need instructions on how to install valve opposite boost valve it is the only other valve held in by a snap ring that is visible from bottom of trans not in valve body? removed it by mistake thinking it was the boost valve and don't know which spring goes where. there are two different springs, valve, washer, and snap ring. i know that the washer and snap clip are last but don't know where the rest goes.
thanks much,
99SilverC5A4
