4l80e nightmare
Old Aug 20, 2005 | 12:29 PM
lenny's Avatar
Question 4l80e nightmare
Has reverse only will go forward but you have to crank up the rpms to 5000 any ideas
Old Aug 20, 2005 | 02:21 PM
strokedls1's Avatar
Burnt clutches, or maybe cut seal bleeding pressure. I had a bad seal after a rebuild and had to rev the hell out of it to get it to move. It is all just guessing until you pull it apart though.
Old Aug 20, 2005 | 03:35 PM
cablebandit's Avatar
broken sprag...does it whine?
Old Aug 20, 2005 | 04:03 PM
jxaxsxoxn's Avatar
Worn boost valve causeing high pressure and blew out the forward piston seals.
Or the forward clutch cushion spring broke and is jammed up in the drum.
Do a pressure test it will tell you if it's hydrualic or mechanical.
