What's the difference between a TH350 and a TH400?
Old Jan 29, 2002 | 02:37 PM
Beeler422's Avatar
Back in the staging lane
Default What's the difference between a TH350 and a TH400?
What is the difference in them? Thanks.
Old Jan 29, 2002 | 03:53 PM
BIGBOS's Avatar
Default Re: What's the difference between a TH350 and a TH400?
350 is smaller and meant more for direct drag racing and little street driving...the th400 is bigger and stronger for all around purposes... <img src="gr_stretch.gif" border="0">
If you want to drive on the street more get the TH400, because with the TH350 you will need to rebuild every 6000 miles or so...
Old Jan 29, 2002 | 05:06 PM
C5 Hardtop's Avatar
Strength <img src="gr_stretch.gif" border="0"> The TH350 usually goes behind the old 350's and the TH400 goes behind the bigger engines such as the 454,455 etc.
Joel
Old Jan 30, 2002 | 12:43 AM
zombiedude's Avatar
Just a note. the th400 guts were used in the older JAGS. hhmmmmm
Old Jan 30, 2002 | 09:22 AM
Colonel's Avatar
I wouldn't say that a TH350 is meant more for drag racing than a 400 is. A TH350 can be made to be a VERY strong transmission (some tranny builders say just as strong or even stronger than a TH400 can be built) that will hold up to alot of abuse for alot of miles. I haven't managed to damage mine yet. I couldn't tell you how many high 9 and low 10 passes it has endured it since installation last summer, but it's ALOT for that amount of time. Street driving would be much easier on it than what I put it through.
Also, TH350s can be had with a lockup converter. Many came from the factory that way (the later model ones.)
The TH350 comes with slightly more desirable gearing. Stock gearing between the two are as follows...
TH350
1st 2.52
2nd 1.52
3rd 1.00
TH400
1st 2.48
2nd 1.48
3rd 1.00
Optional aftermarket gear ratios are available for either. For example, I have a 2.75 1st gear ratio in my TH350.
Other differences are that a TH350 is considerably smaller, lighter, and somewhat easier to turn (saps less power.)
Do I think that a TH400 can actually be stronger? Well, stock for stock, the TH400 is certainly stronger. Once the two are fully performance built, I really don't know but if I had to guess I would say the TH400 could be stronger. What I do know is that I don't yet have enough power to destroy this TH350 so I have no reason to look further at this point. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ January 30, 2002: Message edited by: Colonel ]</p>
Old Jan 30, 2002 | 03:49 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Interesting point there Col, I recall Jay Billinsgley, one of our sponsors, running a T350 that had a manual lockup. I think it was a 1980's VAN application.
Old Jan 31, 2002 | 07:03 PM
Skelton's Avatar
P.I. sells lockup kits for t-350 and t-400's.
Old Jan 31, 2002 | 07:05 PM
Skelton's Avatar
By the way, A turbo 400 can be built to quite abit more power capacity than a t-350. There was a company in GA that was making them for some 1800hp Pro-mods years back and they actually lived. They dont use them anymore due to alot better clutchless technology now.
Old May 13, 2018 | 05:45 PM
Fishmaster5's Avatar
Default Th400 was behind small engines too
Joel
My first truck was an 88 regular cab short bed Chevy and it had a 305 backed by a th400
Old May 13, 2018 | 06:08 PM
98CayenneT/A's Avatar
sorry bud but the last post in this thread was 16 years ago.
Old May 13, 2018 | 06:16 PM
I saw that right after I posted it
Old May 13, 2018 | 10:23 PM
Game ova's Avatar
This has to be a record
Old May 14, 2018 | 02:37 AM
RPM WS6's Avatar
LS1Tech Administrator
Let's put this ancient thread back to bed. Pointless bump IMO. But, since it's back...
Definitely not the case unless the parts and/or builder are of the lowest possible order of quality/competence, or you're vastly exceeding the build capacity of the trans in question.
