Tranny is acting weird...
Old Sep 9, 2005 | 09:22 PM
RunNE1's Avatar
Default Tranny is acting weird...
Wanted to see if anyone can help out. The first thing is that the when I floor it in first gear, it barely chirps the tires. The tires barely spin and then it seems like something is holding the car back(T/C is off)all the way through the revs. Then when it goes to shift it hits hard and does a hard scratch of the tires when it goes into the next gear. I can even manually hold it in first at 5000 and floor it and it still does not burn tires. Either the car has lost tons of power or there is something going on with the driveline. One other thing is that the car used to shift into OD lockup at just after 40. Now the car will not go into lockup until after 55 mph.
Old Sep 9, 2005 | 10:24 PM
'01 WS6 TA's Avatar
Sounds like a converter issue to me....
Josh
