A4 not shifting
Old Feb 4, 2002 | 10:05 AM
sspooky's Avatar
Default A4 not shifting
I was at the track this weekend, and on my last run something odd happened. I had the car in D, but for some reason, it wouldn't shift into 3rd. It just kept hitting the rev-limiter in 2nd. I double checked at the end of the run to make sure I actually had the car in drive and not 2nd by accident, but it was indeed in drive. I was able to drive home without incident, and the tranny behaved normally.
My question is, what happened? The car is completely stock, and I was able to make 2 other runs earlier with no problem. How much should I be worried by this?
Old Feb 4, 2002 | 02:56 PM
Ragtop 99's Avatar
Default Re: A4 not shifting
did you try running with the car in OD? My car shifts fine in OD, but will often tag the 2-3 limiter in D.
Old Feb 4, 2002 | 03:05 PM
Chris99WS6PWTMET's Avatar
My 99 did the same thing. Get an HPP3 and adjust your rev limiter and shift points. That will cure it.
