2, d, od to 1, 2, d, od...HELP!!!!!
Old Sep 19, 2005 | 12:35 AM
griff71177's Avatar
Exclamation 2, d, od to 1, 2, d, od...HELP!!!!!
My friend has an LT1 Camaro and I have an LS1 Firebird, both automatics. My transmission is numbered 1, 2, d, od. His is 2, d, and od. He asked me if there was a way to make his tranny like mine to where he can shift gears and put his car in first and keep it there like I can with mine? Anybody know anything that could help him out. He was going about 35-40mph and got beat by a mustang off the jump because his car didn't downshift to 1st, just ran out second gear. HOW EMBARRASING for him!!!!!!!!!!!!!!!! hahahahahahahaha!!!!! I laughed @ him. anyway...if you know of anything that could help him out let me know. Thanks!!!
Griff
Old Sep 19, 2005 | 12:43 AM
B.W.'s Avatar
You should always keep your cars in drive for racing. You are using the same gears, just let the computer do the shifting for you. You will either shift too early or too late, it's not worth it.
Old Sep 19, 2005 | 12:56 AM
94greencamaro's Avatar
It probably didnt downshift to one because because his mph was past the set shift point for first gear. He doesn't have 1st selectable because his car has 2.73 gears. B.W is right, you shouldnt shift it yourself anyway. You can make it have a first gear though. Pop of the plastic cover and you will see a resistor block blocking out the selection of 1st gear. Take a knife or something and pop the bitch, you now can select first gear.
Old Sep 19, 2005 | 01:07 AM
SmokingWS6's Avatar
In the early 90's due to some sound regulation apparently the good old epa(i think( )) determinded the lt1 was to loud to be pulled down into 1st manually. Its basically in the shifter.. If he can find a shifter and console out of a car that allows you to pull down into first he'll be able to do it.
Old Sep 19, 2005 | 01:13 AM
Yeah i know all that
But he doesnt need a new shifter. You can just cut out the little block that is stopping the car from going into first and then it is selectable. Do a search on yahoo if you want to see pics.
