Rebuild/New Tranny?
Obviously my tranny is failing me but what would you do? Rebuild/fix and put a 3 speed in it or just get a bullet-proof transmission. This car is primarily driven at the track twice a month; and once-in-a-blue-moon I will drive it 5 miles down the road to the lake. Any suggestions appreciated. Thanks gotta go cry now!!
anyways... to try and help with your situation... i don't know what is causing your problem, but if you want to get a new trans, or a rebuild... i say go with a t350 or t400 trans with a manual valve body and a trans brake. LOTS OF FUN!!! very strong too.
I made the same move you did from 2.73's to 3.73's. I was cutting 1.6's with the 3.73's AND ET Streets. You need to check the fluid in your tranny, need to keep it full. If you don't already have a tranny cooler you need one. Check the dipstick for a redish dust (kinda looks like the dipstick is rusting) that is clutch dust, not a good thing. Also, smell the fluid, does it smell worse than normal (I hate the smell of tranny fluid new or used
). The second to third shift seems like it is always the first to go
but it may just be a little low on fluid (don't over fill to compensate). Good Luck! Keep me posted
