Trans Mount Crossmember Stud-Torque Spec?
On JRP's torque spec list I found the following specs :
I see "trans mount to trans bolt 18 -ft pds" (thats what I set it at)
The other spec I see is "stud, auto trans case extension(Y-car) 13-16 ft pd"
Im not sure if either is the correct torque spec. Does anyone know the correct torque spec for the trans mount cross member stud?
Thanks,
Lane
http://installuniversity.com/install...y_mount_m6.htm
