Gear Vendors OD Unit
Old Oct 2, 2005 | 01:02 AM
SSnakekiller's Avatar
Default Gear Vendors OD Unit
OK, I just want to know how many of your have or know someone that has the TH400 set up with GV OD? And, any regrets? Any problems? I have heard/read you can turn it off so the TH400 sort of 'ignores' the OD unit. Is this true? With the switch off you will just have the normal 3 gears?
Anyone daily drive this setup? How is it?
Old Oct 2, 2005 | 07:40 PM
no one?
Old Oct 2, 2005 | 07:45 PM
MRZ28's Avatar
I would like too Know more about this also....
TTT
Old Oct 2, 2005 | 08:24 PM
john kilgore's Avatar
Default gv
just remember that the th400 has an open converter. if you have a lot of stall in od the tc will slip. probably an 11" is the smallest with 3.5s to 3.70 will work. the gv will let you run a wide ratio trans and shift first-first over second-second over etc. good luck
