Tranny temp guage
Old Oct 5, 2005 | 07:54 PM
GT Griller's Avatar
Default Tranny temp guage
Where did every one mount theres?
Old Oct 5, 2005 | 08:10 PM
71camaro's Avatar
pillar pod
Old Oct 5, 2005 | 09:23 PM
DevonsZ's Avatar
Ac vent above the headlight switch.
Old Oct 6, 2005 | 01:56 AM
nrayome98TA's Avatar
Vent above radio, closest to steering wheel.
Old Oct 6, 2005 | 08:36 AM
GregWS6&z28's Avatar
dual gauge pod
Old Oct 6, 2005 | 09:17 AM
Kenafin_02TA's Avatar
pillar pod
Old Oct 6, 2005 | 12:08 PM
BubaGumpShrimp's Avatar
i just bought that gage along with an oil temp and vac/boost and will mount all three in the ac vents above tthe radio(ta car) dont know about the camaro's
Old Oct 6, 2005 | 12:29 PM
Detroitmuscle's Avatar
I'm thinking about mounting mine next to the TC swith, anyone else done this? Will it even fit?
Old Oct 6, 2005 | 03:44 PM
radz282003's Avatar
Pillar pod. Little fabrication needed.
Old Oct 6, 2005 | 03:59 PM
00NBMCamaro's Avatar
here is where mine is mounted.
Old Oct 6, 2005 | 04:28 PM
GT Griller's Avatar
where did u get the little plate to cover the whole?
Old Oct 6, 2005 | 04:35 PM
looks like the plastic pannels they sell for custom radio installs, cheap as hell. www.partsexpress.com has them.
here check this link, they have other thicknesses also http://www.partsexpress.com/pe/showd...number=265-940
Old Oct 6, 2005 | 06:27 PM
mine was super cheap. the only material that i could find that was relatively the same texture as stock plastic console was a lid for a rubbermade storage container from walmart. cost like 3 bucks for a huge lid. i then cut out a size that would fit the area that needed to be covered. once i had that done i measured the size of the gauge after the bezel and cut the circle out. primed and painted everything and superglued the panel to the console. worked perfect but took like 10 tries to get it to fit right.
Old Oct 7, 2005 | 02:28 AM
Blacker's Avatar
http://www.black98.cz28.com/photo6.html
Old Oct 7, 2005 | 08:11 AM
fasttagurl's Avatar
Left-side pillar pod to keep all my AC vents!!
Old Oct 7, 2005 | 09:20 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
pillar pod.
SteveC
