Trouble adjusting A4 shifter after converter install
Old Oct 9, 2005 | 11:54 PM
69_YENKO's Avatar
Default Trouble adjusting A4 shifter after converter install
we just finished up doing a TC install into a buddies Z28, its all back togther and we started it up to top off the tranny fluid and the shifter is all out of wack. initialy on start up while in park the wheels were turning and grinding aganist the park pin(it was making a nasty clicking noise). i have messed with it alittle now trying to adjust it by removing the plastic clip and sliding the cable around forward/back, is there a certian way to do it?
we have park and reverse, but no neutral its going P-R-OD-D-2-1-1 it feels like it has 5 forward gears. I guess its stuck between gears.
this is an '02 Z28, stock 4l60e with stock shifter and a 4,000 fuddle converter.
any help is appreciated, Thanks alot
Old Oct 10, 2005 | 08:24 AM
JasonK94Z's Avatar
http://shbox.com/trans/A4_trans_linkage.html
Old Oct 10, 2005 | 01:35 PM
CAT3's Avatar
Restricted User
Are you sure you have it bolted to the right trans pan bolts? If not, then you wont get it right. There is no reason to have to adjust the cable from a TC Swap.
Old Oct 10, 2005 | 02:54 PM
JasonK94Z's Avatar
I don't know, but I had my trans rebuilt, and had to adjust the cable also. But yeah, I agree, what changed to make you have to adjust it?
Old Oct 10, 2005 | 03:45 PM
69_YENKO's Avatar
Originally Posted by JasonK94Z
thanks alot thats was helpful.
Old Oct 10, 2005 | 03:59 PM
69_YENKO's Avatar
it is bolted up using the correct bolts in the pan. the linkage must be very close because it feels right on to me.with the car up in the air running it through the gears park is fine, as is reverse, OD, D, 2nd, 1st. but when you stick the selector in neutral and take your foot off the brake the wheels start spinning with a forward motion. i wouldnt think this is normal if it is i appoligize. my buddy just called and said off the jack stands the car dosnt move while in neutral, he reved it to the limitrer and it didnt move. every thing seems to be alright now, i was just worried.
